实现人脸跟踪,运行例程第一张脸,为什么不画框?
import sensor, image, time import car from pid import PID # You may need to tweak the above settings for tracking green things... # Select an area in the Framebuffer to copy the color settings. sensor.reset() # Initialize the camera sensor. sensor.set_pixformat(sensor.GRAYSCALE) # use GRAYSCALE. sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed. sensor.skip_frames(10) # Let new settings take affect. sensor.set_auto_whitebal(False) # turn this off. sensor.set_contrast(3) sensor.set_gainceiling(16) # 跳过几帧,让感光元件稳定下来,使设置生效 sensor.skip_frames(time = 2000) # 把True改成False就可以关闭纵向翻转 #sensor.set_vflip(True) # 加载Haar算子 # 默认情况下,这将使用所有阶段,较低的阶段更快但不太准确。 face_cascade = image.HaarCascade("frontalface", stages=25) print(face_cascade) # 第一组关键点 kpts1 = None # Find a face! # 找一张脸! while (kpts1 == None): img = sensor.snapshot() img.draw_string(0, 0, "Looking for a face...") # Find faces objects = img.find_features(face_cascade, threshold=0.5, scale=1.25) if objects: # 在每个方向上将ROI扩大31个像素 face = (objects[0][0]-31, objects[0][1]-31,objects[0][2]+31*2, objects[0][3]+31*2) # 使用检测面大小作为ROI提取关键点 kpts1 = img.find_keypoints(threshold=10, scale_factor=1.1, max_keypoints=100, roi=face) # 在第一个人脸周围画一个矩形 img.draw_rectangle(objects[0],color=120, thickness=10,fill=True )
在脸前面加一个灯光,灯光照在人脸上。
