  • 为什么目标检测中,我将训练好的模型进行识别,在摄像头分辨率为QVGA时位置显示正确,而设置为QQVGA时会出现偏差?
      sensor.set_pixformat(sensor.GRAYSCALE)    # Set pixel format to RGB565 (or GRAYSCALE)
      sensor.set_framesize(sensor.QQVGA)      # Set frame size to QVGA (320x240)
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
              img = sensor.snapshot().lens_corr(1.85)
          # of our objects
         ###  if r:
                 for d in detection_list:
                     [x, y, w, h] = d.rect()
      图一为QVGA
      图二为QQVGA
    • QVGA是320x240,QQVGA是160x120。所以QQVGA不能使用sensor.set_windowing((240, 240)),可以改成120X120或者96x96
