  • 为什么目标检测中,我将训练好的模型进行识别,在摄像头分辨率为QVGA时位置显示正确,而设置为QQVGA时会出现偏差?
    • # Edge Impulse - OpenMV Object Detection Example
      import sensor, image, time, os, tf, math, uos, gc
      sensor.set_pixformat(sensor.GRAYSCALE)    # Set pixel format to RGB565 (or GRAYSCALE)
      sensor.set_framesize(sensor.QQVGA)      # Set frame size to QVGA (320x240)
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
              img = sensor.snapshot().lens_corr(1.85)
          # detect() returns all objects found in the image (splitted out per class already)
          # we skip class index 0, as that is the background, and then draw circles of the center
          # of our objects
         ###  if r:
              for i, detection_list in enumerate(net.detect(img, thresholds=[(math.ceil(min_confidence * 255), 255)])):
                 if (i == 0): continue # background class
                 if (len(detection_list) == 0): continue # no detections for this class?
                 for d in detection_list:
                     [x, y, w, h] = d.rect()
                     print('x %d\ty %d' % (center_x, center_y))
                     img.draw_circle((center_x, center_y, 12), color=colors[i], thickness=2)
      图一为QVGA
      图二为QQVGA
    • QVGA是320x240,QQVGA是160x120。所以QQVGA不能使用sensor.set_windowing((240, 240)),可以改成120X120或者96x96
