  • openmv连接arduino运行不了
    • from pyb import Pin, Timer
      inverse_left=False  #change it to True to inverse left wheel
      ain1 =  Pin('P5', Pin.OUT_PP)
      ain2 =  Pin('P6', Pin.OUT_PP)
      bin1 =  Pin('P9', Pin.OUT_PP)
      bin2 =  Pin('P4', Pin.OUT_PP)
      ain1.low()
      ain2.low()
      bin1.low()
      bin2.low()
      pwma = Pin('P7')
      pwmb = Pin('P8')
      tim = Timer(4, freq=1000)
      ch1.pulse_width_percent(0)
      ch2.pulse_width_percent(0)
          if inverse_left==True:
              left_speed=(-left_speed)
          if inverse_right==True:
              right_speed=(-right_speed)
          if left_speed < 0:
              ain1.low()
              ain2.high()
              ain1.high()
              ain2.low()
          ch1.pulse_width_percent(int(abs(left_speed)))
          if right_speed < 0:
              bin1.low()
              bin2.high()
              bin1.high()
              bin2.low()
          ch2.pulse_width_percent(int(abs(right_speed)))
      上面是openmv代码下面是arduino代码
      void setup()
      pinMode( 5 , OUTPUT );//低电平 正转
      pinMode( 6 , OUTPUT );//高电平 反转
      pinMode( 9 , OUTPUT );//高电平 正转
      pinMode( 4 , OUTPUT );//低电平 正转
      void loop()
      analogWrite( 5 , 0 );
      analogWrite(6,255);
      analogWrite( 9 , 255 );
      analogWrite(4,0);
      然后在openmvIDE里运行脚本摄像头闪彩灯运行不了这是为什么
    • 你的OpenMV的代码,只定义了函数,没有运行函数。
    • 运行函数咋弄,求大神教教
      ain1.low()
      ain2.low()
      bin1.low()
      bin2.low()
      pwma = Pin('P7')
      pwmb = Pin('P8')
          if left_speed < 0:
              ain1.low()
              ain2.high()
              ain1.high()
              ain2.low()
          if right_speed < 0:
              bin1.low()
              bin2.high()
              bin1.high()
              bin2.low()
      run(100,100)
          pass
      但是这个代码和Arudino并没有什么关系。。。
    • 我用的openmv官网追小车的代码怎么能连接上arduino,然后控制他
