openmv连接arduino运行不了
from pyb import Pin, Timer inverse_left=False #change it to True to inverse left wheel inverse_right=False #change it to True to inverse right wheel ain1 = Pin('P5', Pin.OUT_PP) ain2 = Pin('P6', Pin.OUT_PP) bin1 = Pin('P9', Pin.OUT_PP) bin2 = Pin('P4', Pin.OUT_PP) ain1.low() ain2.low() bin1.low() bin2.low() pwma = Pin('P7') pwmb = Pin('P8') tim = Timer(4, freq=1000) ch1 = tim.channel(1, Timer.PWM, pin=pwma) ch2 = tim.channel(2, Timer.PWM, pin=pwmb) ch1.pulse_width_percent(0) ch2.pulse_width_percent(0) def run(left_speed, right_speed): if inverse_left==True: left_speed=(-left_speed) if inverse_right==True: right_speed=(-right_speed) if left_speed < 0: ain1.low() ain2.high() else: ain1.high() ain2.low() ch1.pulse_width_percent(int(abs(left_speed))) if right_speed < 0: bin1.low() bin2.high() else: bin1.high() bin2.low() ch2.pulse_width_percent(int(abs(right_speed)))
上面是openmv代码下面是arduino代码
void setup()
pinMode( 5 , OUTPUT );//低电平 正转
pinMode( 6 , OUTPUT );//高电平 反转
pinMode( 9 , OUTPUT );//高电平 正转
pinMode( 4 , OUTPUT );//低电平 正转
}void loop()
analogWrite( 5 , 0 );
analogWrite(6,255);
analogWrite( 9 , 255 );
analogWrite(4,0);
然后在openmvIDE里运行脚本摄像头闪彩灯运行不了这是为什么
你的OpenMV的代码,只定义了函数,没有运行函数。
运行函数咋弄,求大神教教
from pyb import Pin, Timer inverse_left=False #change it to True to inverse left wheel inverse_right=False #change it to True to inverse right wheel ain1 = Pin('P5', Pin.OUT_PP) ain2 = Pin('P6', Pin.OUT_PP) bin1 = Pin('P9', Pin.OUT_PP) bin2 = Pin('P4', Pin.OUT_PP) ain1.low() ain2.low() bin1.low() bin2.low() pwma = Pin('P7') pwmb = Pin('P8') tim = Timer(4, freq=1000) ch1 = tim.channel(1, Timer.PWM, pin=pwma) ch2 = tim.channel(2, Timer.PWM, pin=pwmb) ch1.pulse_width_percent(0) ch2.pulse_width_percent(0) def run(left_speed, right_speed): if inverse_left==True: left_speed=(-left_speed) if inverse_right==True: right_speed=(-right_speed) if left_speed < 0: ain1.low() ain2.high() else: ain1.high() ain2.low() ch1.pulse_width_percent(int(abs(left_speed))) if right_speed < 0: bin1.low() bin2.high() else: bin1.high() bin2.low() ch2.pulse_width_percent(int(abs(right_speed))) run(100,100) while True: pass
但是这个代码和Arudino并没有什么关系。。。
我用的openmv官网追小车的代码怎么能连接上arduino,然后控制他
