  • 我想先识别白纸,然后在白纸上识别圆形,应该怎样改动这个代码呢?
    • # Single Color RGB565 Blob Tracking Example
      # This example shows off single color RGB565 tracking using the OpenMV Cam.
      import sensor, image, time, math, lcd
      thresholds = [(67, 100, -128, 37, -128, 69)] # generic_blue_thresholds
      blob=[0,0,16000,16000]
      lcd.init()
          for blob in img.find_blobs([thresholds[threshold_index]],pixels_threshold=200, area_threshold=19000, merge=True):
              if blob.elongation() > 0.5:
                  img.draw_edges(blob.min_corners(), color=(255,0,0))
                  img.draw_line(blob.major_axis_line(), color=(0,255,0))
                  img.draw_line(blob.minor_axis_line(), color=(0,0,255))
              for c in img.find_circles(threshold=3500,  left_roi = [blob[0],blob[1],blob[2],blob[3]], x_margin=10, y_margin=10, r_margin=10, r_min=2, r_max=100, r_step=2):
                  img.draw_circle(c.x(), c.y(), c.r(), color=(255, 0, 0))
                  img.draw_string(0,0,'x='+str(blob.cx()), color=(255,0,0))
                  img.draw_string(0,10,'y='+str(blob.cy()), color=(255,0,0))
                  img.draw_string(0,20,'h='+str(blob.h()), color=(255,0,0))
                  img.draw_string(0,30,'w='+str(blob.w()), color=(255,0,0))
                  lcd.display(img) # Take a picture and display the image.
    • 有没有实际图片?
    • @kidswong999 0_1653556695490_D2674E3374216F5614E4611DA07B5F5D.jpg 大概是这样的
    • 你这个就直接找红色的色块就行了。
