  • 云台追踪人脸失败,请问怎么解决???
      from pyb import Servo
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      # 感光元件设置
      sensor.set_contrast(3)
      # HQVGA and GRAYSCALE are the best for face tracking.
      # HQVGA和灰度对于人脸识别效果最好
          if objects:
              max_blob = find_max(objects)
      云台追踪人脸,出现这样的问题求大佬帮忙解决谢谢
