  • 云台追踪人脸失败,请问怎么解决???
      from pyb import Servo
      pan_servo=Servo(1)
      tilt_servo=Servo(2)
      pan_servo.calibration(500,2500,500)
      tilt_servo.calibration(500,2500,500)
      red_threshold  = (13, 49, 18, 61, 6, 47)
      # 感光元件设置
      sensor.set_contrast(3)
      # HQVGA and GRAYSCALE are the best for face tracking.
      # HQVGA和灰度对于人脸识别效果最好
          if objects:
              max_blob = find_max(objects)
              pan_error = max_blob[0]+max_blob[2]/2-img.width()/2
              tilt_error = max_blob[1]+max_blob[3]/2-img.height()/2
      云台追踪人脸,出现这样的问题求大佬帮忙解决谢谢
