  • 如何在垃圾识别代码上写代码使识别到的垃圾上画框圈住,并且返回那个框的中心坐标
    • import sensor, image, time, os, tf, lcd
      uart = UART(3, 19200)
      a = 0
      sensor.skip_frames(time=2000)
      lcd.init()
      net = "trained.tflite"
      b =(max(zip( obj.output(),labels)))
      b =b[1]
      print(b)
      uart.write(b+'\n')
      if uart.readline():
      c = uart.readline()
      print(c)
      time.sleep_ms(2000)
      if b == ('blank'):
      a = a
      a = a+1
      img.draw_string(10,10,str(a)+'\n' + str(b)+'\n'+'1'+'\n'+'ok')
      lcd.display(img)
      time.sleep_ms(3000)
      print(clock.fps(), "fps")
    • 目前神经网络只有分类,不能目标查找。
