如何在垃圾识别代码上写代码使识别到的垃圾上画框圈住,并且返回那个框的中心坐标
import sensor, image, time, os, tf, lcd
uart = UART(3, 19200)
a = 0
sensor.skip_frames(time=2000)
lcd.init()
net = "trained.tflite"
b =(max(zip( obj.output(),labels)))
b =b[1]
print(b)
uart.write(b+'\n')
if uart.readline():
c = uart.readline()
print(c)
time.sleep_ms(2000)
if b == ('blank'):
a = a
a = a+1
img.draw_string(10,10,str(a)+'\n' + str(b)+'\n'+'1'+'\n'+'ok')
lcd.display(img)
time.sleep_ms(3000)
print(clock.fps(), "fps")
目前神经网络只有分类,不能目标查找。
