  • 求助关于人脸分辨的相关问题
    • 你好请问这个人脸识别代码为什么不能输出num的值,串行口显示没有输出值,万分感谢
      num = 0
      def min(pmin, a, s):
          global num
          print(00000000)
          if a < pmin:
              pmin = a
              num = s
          return pmin
          NUM_SUBJECTS = 2
          NUM_SUBJECTS_IMGS = 20
          img = None
          pmin = 999999
          num = 0
          for s in range(1, NUM_SUBJECTS + 1):
              dist = 0
              for i in range(2, NUM_SUBJECTS_IMGS + 1):
                  img = image.Image("singtown/s%d/%d.pgm" % (s, i))
                  dist += image.match_descriptor(d0, d1)
              print("Average dist for subject %d: %d" % (s, dist / NUM_SUBJECTS_IMGS))
              pmin = min(pmin, dist / NUM_SUBJECTS_IMGS, s)
              print(pmin)
              if dist / NUM_SUBJECTS_IMGS == pmin:
                  num = s
          print(num)
    • https://singtown.com/learn/50033/
      有没有按照视频的步骤操作?
    • 确实跟着教程一步一步走 但就是分辨不出来
    • @kidswong999 是按照视频的步骤进行的
