  • 多特征点识别时提示错误Descriptors have different types!
    • 代码如下:
      import sensor, time, image
      Reset sensor
      Sensor settings
      sensor.set_contrast(3)
      sensor.set_brightness(-3)
      kernel_size = 1 # kernel width = (size2)+1, kernel height = (size2)+1
      kernel = [-1, -1, -1,
      -1, +9, -1,
      -1, -1, -1]
      print(kpts)
      img.draw_keypoints(kpts)
      time.sleep(1000)
      NOTE: uncomment to load a keypoints descriptor from file
      kpts1 = image.load_descriptor("/SWW_F.orb")
      kpts2 = image.load_descriptor("/SWW_R.orb")
      draw_keypoints(img, kpts1)
      if (kpts1 == None):
      kpts3 = img.find_keypoints(max_keypoints=150, threshold=10, scale_factor=1.2)
      kpts3 = img.find_keypoints(max_keypoints=150, threshold=10, normalized=True)
      if (kpts2):
      match1 = image.match_descriptor(kpts1, kpts3, threshold=85)
      match2 = image.match_descriptor(kpts2, kpts3, threshold=85)
      if (match1.count()>12):
      img.draw_rectangle(match1.rect())
      img.draw_cross(match1.cx(), match1.cy(), size=10)
      if (match2.count()>12):
      img.draw_rectangle(match2.rect())
      img.draw_cross(match2.cx(), match2.cy(), size=10)
      # Draw FPS
      运行一段时间内识别正常,一段时间后于“match1 = image.match_descriptor(kpts1, kpts3, threshold=85)”这句提示错误Descriptors have different types!
    • 你好,我想请问一下你在前文定义的kernel是有什么作用吗?
    • @kidswong999 感觉你在卖队友哈哈哈
    • 应该是先利用img.morph对图像进行了卷积运算。
