MemoryError:Out of fast Frame Buffer Stack Memory!
import sensor, image, time sensor.reset() # Initialize the camera sensor. sensor.set_pixformat(sensor.RGB565) # use RGB565. sensor.set_framesize(sensor.QQVGA) # use QVGA for quailtiy ,use QQVGA for speed. sensor.skip_frames(10) # Let new settings take affect. sensor.set_auto_whitebal(False) #关闭白平衡。白平衡是默认开启的,在颜色识别中,需要关闭白平衡。 clock = time.clock() # Tracks FPS. weed_threshold_01 = ((31, 100, -128, -12, 0, 127)) ''' 扩宽roi ''' def expand_roi(roi): # set for QQVGA 160*120 extra = 5 win_size = (160, 120) (x, y, width, height) = roi new_roi = [x-extra, y-extra, width+2*extra, height+2*extra] if new_roi[0] < 0: new_roi[0] = 0 if new_roi[1] < 0: new_roi[1] = 0 if new_roi[2] > win_size[0]: new_roi[2] = win_size[0] if new_roi[3] > win_size[1]: new_roi[3] = win_size[1] return tuple(new_roi) while(True): clock.tick() img = sensor.snapshot() blobs = img.find_blobs([weed_threshold_01], area_threshold=150) if blobs: #如果找到了目标颜色 # print(blobs) for blob in blobs: #迭代找到的目标颜色区域 is_rect = False max_area = 0 new_roi = expand_roi(blob.rect()) rects=img.find_rects(roi=new_roi,threshold = 10000) if rects: is_rect=True for rect in rects: print(rects) if rect.w()*rect.h() > max_area: max_area = rect.w()*rect.h() max_circle = rect img.draw_rectangle(max_circle.x(),max_circle.y(),max_circle.w(),max_circle.h()) print(clock.fps())
我使用OpenMV4测试这个代码,没有出现错误。
请提供一下出现错误的方法。
小智智,我是在EDGR IMPULSE 导入神经网络出现这个错误,使用型号是OPENMV4 H7 CAM(不是PLUS),可以解决吗这个报错
@kidswong999
小智智,我是在导入 EDGE IMPLUSE 神经网络的例程.py 出现的这个报错,型号是MV4 H7 CAM (NO PLUS)
@bhkl edge impulse的模型只能在OpenmV4 Plus上用,OpenMV4不行。
@kidswong999 好,谢谢您
