  • MemoryError:Out of fast Frame Buffer Stack Memory!
    • import sensor, image, time
      sensor.set_framesize(sensor.QQVGA) # use QVGA for quailtiy ,use QQVGA for speed.
      weed_threshold_01 = ((31, 100, -128, -12, 0, 127))
        扩宽roi
      def expand_roi(roi):
          # set for QQVGA 160*120
          extra = 5
          win_size = (160, 120)
          (x, y, width, height) = roi
          new_roi = [x-extra, y-extra, width+2*extra, height+2*extra]
          if new_roi[0] < 0:
              new_roi[0] = 0
          if new_roi[1] < 0:
              new_roi[1] = 0
          if new_roi[2] > win_size[0]:
              new_roi[2] = win_size[0]
          if new_roi[3] > win_size[1]:
              new_roi[3] = win_size[1]
          return tuple(new_roi)
          blobs = img.find_blobs([weed_threshold_01], area_threshold=150)
          #如果找到了目标颜色
            #  print(blobs)
              #迭代找到的目标颜色区域
                  is_rect = False
                  max_area = 0
                  new_roi = expand_roi(blob.rect())
                  rects=img.find_rects(roi=new_roi,threshold = 10000)
                  if rects:
                      is_rect=True
                      for rect in rects:
                          print(rects)
                          if rect.w()*rect.h() > max_area:
                              max_area = rect.w()*rect.h()
                              max_circle = rect
                          img.draw_rectangle(max_circle.x(),max_circle.y(),max_circle.w(),max_circle.h())
    • 我使用OpenMV4测试这个代码,没有出现错误。
      请提供一下出现错误的方法。
      小智智,我是在EDGR IMPULSE 导入神经网络出现这个错误,使用型号是OPENMV4 H7 CAM(不是PLUS),可以解决吗这个报错
    • @kidswong999 0_1644716622344_QQ图片20220213094104.png 小智智,我是在导入 EDGE IMPLUSE 神经网络的例程.py 出现的这个报错,型号是MV4 H7 CAM (NO PLUS)
    • @bhkl edge impulse的模型只能在OpenmV4 Plus上用,OpenMV4不行。
    • @kidswong999 好,谢谢您
