  • AttributeError:'Inage' object has no attribute 'find_number'
      # LetNet Example
      sensor.set_contrast(3)
      sensor.set_windowing((28, 28))
      sensor.set_auto_gain(False)
          out = img.invert().find_number()
          if out[1] > 3.0:
              print(out[0])
          #print(clock.fps())             # Note: OpenMV Cam runs about half as fast when connected
    • image对象中没有find_number吗?
