  • AttributeError:'Inage' object has no attribute 'find_number'
      # LetNet Example
      sensor.set_contrast(3)
      sensor.set_pixformat(sensor.GRAYSCALE) # Set pixel format to RGB565 (or GRAYSCALE)
      sensor.set_windowing((28, 28))
      sensor.set_auto_gain(False)
      sensor.set_auto_exposure(False)
          clock.tick()                    # Update the FPS clock.
          out = img.invert().find_number()
          if out[1] > 3.0:
              print(out[0])
          #print(clock.fps())             # Note: OpenMV Cam runs about half as fast when connected
                                          # to the IDE. The FPS should increase once disconnected.
    • image对象中没有find_number吗?
