  • 怎么使用“threshold.value()”拿出阈值.
    • 利用“histogram.get_threshold()”得到最佳阈值后,想使用“threshold.value()”拿出阈值,失败了..😭 😭
      THRESHOLD = [0, 100] # Grayscale threshold for dark things...
      BINARY_VISIBLE = True # Does binary first so you can see what the linear regression
                            # is being run on... might lower FPS though.
      from pyb import LED
      LED(1).on()
      LED(2).on()
      LED(3).on()
          img = sensor.snapshot().lens_corr(strength = 0.5, zoom = 1.0)
          img.gaussian(3, unsharp=True)
          histogram = img.get_histogram()#得到直方图
          Thresholds = histogram.get_threshold()#得到最佳阈值
          THR=threshold.value()#获取当前阈值
          #img.binary([THRESHOLD])if BINARY_VISIBLE else sensor.snapshot()
          line = img.get_regression([(255,255) if BINARY_VISIBLE else THRESHOLD], robust = True)
          if (line): img.draw_line(line.line(), color = 127)
    已锁定
