怎么使用“threshold.value()”拿出阈值.
利用“histogram.get_threshold()”得到最佳阈值后,想使用“threshold.value()”拿出阈值,失败了..
THRESHOLD = [0, 100] # Grayscale threshold for dark things... BINARY_VISIBLE = True # Does binary first so you can see what the linear regression # is being run on... might lower FPS though. import sensor, image, time from pyb import LED sensor.reset() sensor.set_pixformat(sensor.GRAYSCALE) sensor.set_framesize(sensor.QQQVGA) # 80x60 (4,800 pixels) - O(N^2) max = 2,3040,000. sensor.skip_frames(time = 2000) # WARNING: If you use QQVGA it may take seconds clock = time.clock() # to process a frame sometimes. LED(1).on() LED(2).on() LED(3).on() while(True): clock.tick() img = sensor.snapshot().lens_corr(strength = 0.5, zoom = 1.0) img.gaussian(3, unsharp=True) histogram = img.get_histogram()#得到直方图 Thresholds = histogram.get_threshold()#得到最佳阈值 THR=threshold.value()#获取当前阈值 #img.binary([THRESHOLD])if BINARY_VISIBLE else sensor.snapshot() line = img.get_regression([(255,255) if BINARY_VISIBLE else THRESHOLD], robust = True) if (line): img.draw_line(line.line(), color = 127)
