  • 不明白编译器的错误提示,请指点一下
    • 1.单独运行各个模块没有提示语法错误,但编译main.py时提示我的R_G_B方法名字定义出错
      2.编译时编译器提示将我的sending模块更新,如果更了之后,又会变回以前错的那样(我编译时都选不更新才会照着新写得模块遍历2_1549443826947_H__Measure.py - OpenMV IDE 2019_2_6 17_01_50.png 1_1549443826947_H__Measure.py - OpenMV IDE 2019_2_6 17_01_46.png 0_1549443826947_H__Measure.py - OpenMV IDE 2019_2_6 16_53_49.png )
      Measure.py
      # Untitled - By: 李俊健 - 周四 1月 24 2019
      #按扫码数字顺序进行红绿蓝颜色识别
      # Single Color RGB565 Blob Tracking Example
      # This example shows off single color RGB565 tracking using the OpenMV Cam.
      import sensor,image,math,time
      import sending
      import r_g_b
      thresholds = [(30, 100, 15, 127, 15, 127), # generic_red_thresholds     #只有红色
                    (30, 100, -64, -8, -32, 32), # generic_green_thresholds   #只有绿色
                    (0, 30, 0, 64, -128, 0)] # generic_blue_thresholds        #只有蓝色
      #接收32的命令,1-找红色物料,2-找—绿色物料,3-找蓝色物料,并返回距离
      #while (True):
      #    View_Color()
      # Measure the distance
      # This example shows off how to measure the distance through the size in imgage
      # This example in particular looks for yellow pingpong ball.
      #yellow_threshold   = ( 56,   83,    5,   57,   63,   80)
      m = sending.receive_data()
      K=500 #the value should be measured  需根据要识别物体来确定初始化比例大小
      #实际大小=K*宽的像素
      def measure_distance(m):
          blobs = r_g_b.R_G_B(m)
          if len(blobs) == 1:
              b = blobs[0]
              if abs(b[2]-b[3])>2:    #判断是否为球、正方体或其他立方体
                  Lm = b[3]
                  Lm = (b[2]+b[3])/2
              length = K/Lm               #距离 = k/直径的像素
          return length
              #print(b[2])
      #while True:
      #    Measure_Distance()
          #print(clock.fps()) # Note: Your OpenMV Cam runs about half as fast while
      main.py
      # Untitled - By: Lee - 周六 1月 26 2019
      # 收开始命令 扫码  找色块 测距 发距离
      from sending import receive_data
      from sending import sending_data
      import Sao_Ma
      import Measure
      uart = UART(3, 19200)
          order = receive_data()
          if order == 1:              #开始执行命令
              fan_kui = Sao_Ma.ma()          #扫码
              uart.write('fan_kui')     #反馈扫码的数字(整数)
              time.sleep(1000)
              N = receive_data()
              if N == 1:
                  L = Measure.measure_distance(N)
                  uart.write('L')       #返回距离大小
              elif N == 2:
                  uart.write('L')
                  if N == 3:
                      uart.write('L')
      r_g_b.py
      #按扫码数字顺序进行红绿蓝颜色识别
      #分别给i赋值1,2,3
      def R_G_B(j):   #寻找最大色块的坐标
          if j <= 3:
              for blob in img.find_blobs([thresholds[j-1]], pixels_threshold=200, \
              area_threshold=200, merge=True):
                      #色块中心的坐标
                  if blob.pixels() > max_size:
                      max_blob = blob
                      max_size = blob.pixels()
                      print('sum :', len(blobs))
      def R_G_B_center(k):
          m = R_G_B(j)
          x = blob.cx()
          y = blob.cy()
          return x,y
      #while True:
      #    R_G_B(1)
      Sao_Ma.py
      import sensor, image,time
      sensor.set_framesize(sensor.QQVGA) # can be QVGA on M7...
      sensor.skip_frames(30)
      def ma():
      img.draw_rectangle(code.rect(),color = (0,0,0))
      numbers = code.payload()
      if code.payload() >= '0':
      numbers = list(map(int, numbers))
      number = numbers[0]*100+numbers[1]*10+numbers[2]
      return nunmer
      #print(number)
      break
      #while (True):
      print(ma())
      sending.py
      # Untitled - By: Lee - 周日 2月 3 2019
      def sending_data(jj):
          global uart
          j = jj
          uart.write('j')     #反馈字符串
      def receive_data():
          global uart
          if uart.any():
              tmp_data = uart.readline()
              uart.write("RECIVED : %s\n"%tmp_data)
              print(tmp_data)
              return tmp_data
              return 1
      #while(True):
      #    sending_data(1)
      #    receive_data()
      #    time.sleep(1000)
    • 可能你把旧的sending.py保存到了电脑的OpenMV项目目录里。
      OpenMV的IDE会自动寻找,并检查是否与OpenMV电路板上的是否一致,如果不一致就会提醒你。
      所以你要在电脑上OpenMV项目目录,检查一下旧版的sending.py
    • @kidswong999 我是从自己新建的文件夹里打开.py文件的,我也试过把电路板和文件夹里的都替换掉,然后IDE还是会找回以前的sending.py文件
    • 你看一下以前的sending.py保存到电脑的哪个文件里了。
