  • LED4(红外灯)如何设置为PWM调光?
    • Note: Only LED(3) and LED(4) can have a smoothly varying intensity, and
      they use timer PWM to implement it. LED(3) uses Timer(2) and LED(4) uses
      Timer(3). These timers are only configured for PWM if the intensity of the
      relevant LED is set to a value between 1 and 254. Otherwise the timers are
      free for general purpose use.
      *请注意:*只有发光二极管(3)和LED(4)可以具有平滑变化的强度,并且他们使用定时器PWM来实现它。LED(3)使用定时器(2)和LED(4)使用定时器(三)。这些定时器只配置为PWM,如果强度的相关LED被设置为1和254之间的值。否则计时器免费用于一般用途。
      上述材料从openmv的GitHub上所得,LED4是可以使用定时器3来实现PWM调光,但是不知道LED4的引脚,如何设置LED4使用定时器3来实现pwm调光?
    • import time
      from pyb import LED
      ir_led    = LED(4)
          ir_led.intensity(0)
          time.sleep_ms(500)
          ir_led.intensity(128)
          time.sleep_ms(500)
          ir_led.intensity(255)
          time.sleep_ms(500)
