  • Ncc模板匹配按照视频教程 识别不出来箭头 阈值调高过也不行 pmg照片传不上去就不传了
      # NCC is not all to useful.
      import time, sensor, image
      # Reset sensor
      ## Set sensor settings
      #sensor.set_contrast(1)
      #sensor.set_gainceiling(16)
      ## Max resolution for template matching with SEARCH_EX is QQVGA
      #sensor.set_framesize(sensor.QQVGA)
      ## You can set windowing to reduce the search image.
      ##sensor.set_windowing(((640-80)//2, (480-60)//2, 80, 60))
      sensor.set_framesize(sensor.QQVGA)   # Set frame size to QVGA (320x240)
      # Load template.
      template = image.Image("/666.pgm")
      # Run template matching
          r = img.find_template(template, 10, step=4, search=SEARCH_EX)
          if r:
             img.draw_rectangle(r)
