大佬,想问一下怎么在代码层面提高物品识别的精度啊,硬件这边神经网络样例拍了一千多个了。
import sensor, image, time, os, tf, math, uos, gc,pyb
from pyb import LED
red_led = LED(1)
sensor.skip_frames(time=2000)
uart = UART(3, 9600)
net = None
labels = None
min_confidence = 0.92
except Exception as e:
colors = [
(255, 0, 0),
( 0, 255, 0),
(255, 255, 0),
( 0, 0, 255),
(255, 0, 255),
( 0, 255, 255),
(255, 255, 255),
r=0
a=0
count=0
b=0
t=0
flag=0
A=C=D=E=H=I=J=K=L=M=N=O=0
if uart.any():
red_led.on()
time.sleep_ms(500)
red_led.off()
start = pyb.millis()
count=0
m=uart.read(1).decode()
if m!='o':
a=int(m)while( count <=6 ): detected = True img = sensor.snapshot() if pyb.millis() - start>5000: uart.write("d") count=7 for i, detection_list in enumerate(net.detect(img, thresholds=[(math.ceil(min_confidence * 255), 255)])): if (i == 0): continue if (len(detection_list) == 0): continue print("********** %s **********" % labels[i]) for d in detection_list: [x, y, w, h] = d.rect() center_x = math.floor(x + (w / 2)) center_y = math.floor(y + (h / 2)) print('x %d\ty %d' % (center_x, center_y)) if center_y>100: if labels[i]=="旺仔" : if center_x<=60: A=A+1 elif center_x>60 and center_x<=165: C=C+1 else: D=D+1 if labels[i]=="王老吉" : if center_x<=60: E=E+1 elif center_x>60 and center_x<=165: H=H+1 else: I=I+1 if labels[i]=="雪花" : if center_x<=60: J=J+1 elif center_x>60 and center_x<=165: K=K+1 else: L=L+1 if labels[i]=="AD" : if center_x<=60: M=M+1 elif center_x>60 and center_x<=165: N=N+1 else: O=O+1 count=count+1 #if detected: # flag=1 #if flag==1: # uart.write("d") # flag=0 list=[A,C,D,E,H,I,J,K,L,M,N,O] Z=max(list) if Z<=3 and Z>0 : uart.write("d") A=C=D=E=H=I=J=K=L=M=N=O=0 elif Z>3: if A==Z : uart.write("A") if C==Z : uart.write("C") if D==Z : uart.write("D") if E==Z : uart.write("E") if H==Z : uart.write("H") if I==Z : uart.write("I") if J==Z : uart.write("J") if K==Z : uart.write("K") if L==Z : uart.write("L") if M==Z : uart.write("M") if N==Z : uart.write("N") if O==Z : uart.write("O") A=C=D=E=H=I=J=K=L=M=N=O=0
1,数据量不够的,一般每个物品1000张图片。
2,神经网络是一个黑盒,代码改不了什么。
3,推荐使用我们的新产品,可以跑yolo,效果好很多。https://singtown.com/product/50933/singtown-ai-vision-module-sc1/
@kidswong999 好的好的谢谢啦
