  • 为什么运行这段代码控制上下的舵机无法正常运动
      from servo1 import Servos
      from machine import I2C, Pin
      pan_pid = PID(p=0.07, i=0, imax=180)
      tilt_pid = PID(p=0.07, i=0, imax=180)
      pan_current = 0
      tilt_current = 0
      sensor.set_vflip(True)
      sensor.skip_frames(10)
      	blobs =img.find_features(face_cascade, threshold=0.75, scale=1.35)
      		pan_error = max_blob[0]+max_blob[2]-img.width()/2
      		tilt_error =max_blob[1]+max_blob[3]-img.height()/2
      		img.draw_rectangle(max_blob)
      		img.draw_cross(int(max_blob[0]+max_blob[2]), int(max_blob[1]+max_blob[3]))
      		print("tilt_output",pan_output)
      		servo.position(0, pan_current + pan_output)
      		pan_current = servo.get_angle()
      		servo.position(1, tilt_current - tilt_output)
      		tilt_current = servo.get_angle()
    • https://book.openmv.cc/example/15-Servo-Shield/main.html
      运行这个代码,舵机会不会动?
