  • 为什么在识别的时候帧率一直下降,还一卡一卡的,求解答,谢谢各位!
    • import sensor, image, time , math , pyb
      sensor.set_auto_gain(False)
      a1=0
                  max_blob = blob
      red_threshold_01 = ((20, 58, 49, 127, -128, 127));
      white_threshold_01 = ((75, 100, 96, -24, 31, -7));
      pink_threshold_01 = ((30, 100, 5, 73, -42, 32));
          blobs = img.find_blobs([red_threshold_01], roi=[0,0,200,200],pixels_threshold=150, area_threshold=500, merge=True, margin=10);
          blobs1 = img.find_blobs([white_threshold_01], pixels_threshold=100, area_threshold=100, merge=True, margin=10);
          #如果找到了目标颜色
              print("ored")
              for b in blobs:
              #迭代找到的目标颜色区
                  x = b[0]
                  y = b[1]
                  width = b[2]
                  height = b[3]
                  img.draw_rectangle([x,y,width,height]) # rec
                  #在目标颜色区域的中心画十字形标记
                  print(b[5],b[6],b[7])
                  X =int(b[5]-img.width()/2)
                  Y =int(b[6]-img.height()/2)
                  if 9<X<100:
                      datax =("ao"+str(X))
                      print("X坐标: ",datax)
                  elif 0<X<10:
                      datax =("aoo"+str(X))
                  elif X==0:
                      datax =("aooo")
                  elif X>99:
                      datax =("a"+str(X))
                  elif -100<X<-9:
                      datax =("b"+str(X))
                  elif -10<X<0:
                      datax =("boo"+str(X))
                  elif X<-99:
                      datax =("b"+str(X))
                  if 9<Y<100:
                      datay =("ao"+str(Y))
                      print("Y坐标: ",datay)
                  elif 0<Y<10:
                      datay =("aoo"+str(Y))
                  elif Y==0:
                      datay =("aooo")
                  elif Y>99:
                      datay =("a"+str(Y))
                  elif -100<Y<-9:
                      datay =("b"+str(Y))
                  elif -10<Y<0:
                      datay =("boo"+str(Y))
                  elif Y<-99:
                      datay =("b"+str(Y))
                  if(a1==60):
                      a1=0
                      uart.write(datax+datay+"\r\n")
                      print("X Y 坐标 : ",datax,datax)
                      a1=a1+1
          for c in img.find_circles(threshold = 3500, x_margin = 10, y_margin = 10, r_margin = 10,
              statistics = img.get_statistics(roi=area)
              #像素颜色统计
              if 75<statistics.l_mode()<100 and -27<statistics.a_mode()<96 and -7<statistics.b_mode()<31:
                  #识别到的白色圆形用红色的圆框出来
                  print("白",c.x(),c.y())
              #像素颜色统计
              print(statistics)
              if 30<statistics.l_mode()<100 and 5<statistics.a_mode()<73 and -42<statistics.b_mode()<32:
                  #识别到的粉色圆形用红色的圆框出来
                  print("粉",c.x(),c.y())
    • find_circles函数比较慢,你应该把103行,和115行,合并在一起。
              #像素颜色统计
                  #识别到的白色圆形用红色的圆框出来
                  #识别到的粉色圆形用红色的圆框出来
