  • 为什么识别蓝色返回的blob.code()为4?为什么不为3?
    • # Untitled - By: ASUS - 周二 9月 6 2022
      import sensor, image, time, pyb, math
      import json, ustruct
      from pyb import UART ,LED
          global max_blob
              if blob[2]*blob[3] > max_size and 50<blob.cy()<150:
      def detect(max_blob):
          global mark
          #judge=0
          #nothing=0
          row_data=[-1,-1]
          print(max_blob.density())
          #mark=([-1,-1],[-1,-1]) #1 yellow 2 green 3 blue 4 red ;1 rect 2 circle 3 rt
          #shape=0 #1是圆 2是矩形 圆形和矩形直接用函数识别,剩下的判断是不是三角形 3是三角形
          #colour=0
          if  max_blob.density()>0.82:
              row_data[0]=max_blob.code()
              row_data[1]=1
          elif max_blob.density()>0.6:
              img.draw_circle((max_blob.cx(), max_blob.cy(),int((max_blob.w()+max_blob.h())/4)))
              row_data[1]=2
          elif max_blob.density()>0.4:
                  row_data[1]=3
          return row_data
      def sending_data(a,b):
          global uart;
          #data = bytearray(frame)
          data_end = ustruct.pack("<bbhhb",      #格式为俩个字符俩个短整型(2字节)
                         0x2C,                      #帧头1
                         0x12,                      #帧头2
                         int(a), # up sample by 4   #数据1
                         int(b), # up sample by 4    #数据2
                         0x5B)
          uart.write(data_end);   #必须要传入一个字节数组
      red=(8, 55, 73, 10, -71, 57)
      green=(63, 22, -83, -4, 50, -23)
      blue=(52, 7, 40, -73, -15, -117)
          img = sensor.snapshot().lens_corr(strength = 1.8, zoom = 1.0)#畸变矫正
          blobs = img.find_blobs([red,green,blue],area_threshold=100
          data=detect(find_max(blobs))
          print(data)
          sending_data(data[0],data[1])
          #uart.write(jsonstr)
          #break
          #print(clock.fps())
    • 你的阈值是红绿蓝,(0, 0, 1),code的二进制就是100(高位在前),十进制就是4。这么设计是为了识别颜色组合。
