识别蓝色方块时如果方块旋转一定角度就识别成圆 而且有时候不在镜头正中间或者镜头倾斜一定角度就识别不到或者识别错误?
# Untitled - By: ASUS - 周二 9月 6 2022 import sensor, image, time, pyb, math import json, ustruct from pyb import UART ,LED #********************************************************************* def find_max(blobs): max_size=0 global max_blob for blob in blobs: if blob[2]*blob[3] > max_size and 50<blob.cy()<150: max_blob=blob max_size = blob[2]*blob[3] return max_blob #********************************* def detect(max_blob): global mark #judge=0 #nothing=0 row_data=[-1,-1] print(max_blob.density()) #mark=([-1,-1],[-1,-1]) #1 yellow 2 green 3 blue 4 red ;1 rect 2 circle 3 rt #shape=0 #1是圆 2是矩形 圆形和矩形直接用函数识别,剩下的判断是不是三角形 3是三角形 #colour=0 if max_blob.density()>0.82: row_data[0]=max_blob.code() img.draw_rectangle(max_blob.rect()) row_data[1]=1 elif max_blob.density()>0.6: img.draw_circle((max_blob.cx(), max_blob.cy(),int((max_blob.w()+max_blob.h())/4))) row_data[0]=max_blob.code() row_data[1]=2 elif max_blob.density()>0.4: img.draw_cross(max_blob.cx(), max_blob.cy()) row_data[0]=max_blob.code() row_data[1]=3 return row_data #********************************* def sending_data(a,b): global uart; #frame=[0x2C,18,cx%0xff,int(cx/0xff),cy%0xff,int(cy/0xff),0x5B]; #data = bytearray(frame) data_end = ustruct.pack("<bbhhb", #格式为俩个字符俩个短整型(2字节) 0x2C, #帧头1 0x12, #帧头2 int(a), # up sample by 4 #数据1 int(b), # up sample by 4 #数据2 0x5B) uart.write(data_end); #必须要传入一个字节数组 #******************************************************************** red=(8, 55, 73, 10, -71, 57) green=(63, 22, -83, -4, 50, -23) blue=(52, 7, 40, -73, -15, -117) sensor.reset() sensor.set_pixformat(sensor.RGB565) sensor.set_framesize(sensor.QVGA) sensor.skip_frames(time = 2000) uart = UART(3, 115200) uart.init(115200, bits=8, parity=None, stop=1) # init with given parameters clock = time.clock() #******************************************************************** while(True): clock.tick() img = sensor.snapshot().lens_corr(strength = 1.8, zoom = 1.0)#畸变矫正 blobs = img.find_blobs([red,green,blue],area_threshold=100 ) data=detect(find_max(blobs)) print(data) sending_data(data[0],data[1]) #uart.write(jsonstr) #break #print(clock.fps())
方形如果旋转了,那么最外框就变了,所以density就变了。
这种情况,用roundness分析一下
https://docs.singtown.com/micropython/zh/latest/openmvcam/library/omv.image.html#blob.roundness
