  • openmv脱机运行能正常发送数据,但是不能接收数据,这是为什么?
    • openmv在IDE运行时,串口接收和发送数据都是正常的,但是脱机运行时,能正常发送数据却不能正常接收数据,这是什么原因?
      from pyb import UART, Timer, LED
      sensor.skip_frames(time=2000)
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
      colors = [
      	(255,   0,   0),
      	(  0, 255,   0),
      	(255, 255,   0),
      	(  0,   0, 255),
      	(255,   0, 255),
      	(  0, 255, 255),
      	(255, 255, 255),
      global uart_r
      uart_r = [0xAA, 0xAF, 0x05, 0x02, 0x00, 0x00, 0x00, 0x00]
      class Saveimage(object):
      	def __init__(self):
      		pass
      	def Recognize(self,img):
      		self.img = img
      		for i, detection_list in enumerate(net.detect(self.img, thresholds=[(math.ceil(min_confidence * 255), 255)])):
      			if (i == 0): continue
      			if (len(detection_list) == 0): continue
      			print("recognize to: "+labels[i])
      			if labels[i]=='lin':
      				sensor.snapshot().save("lin.jpg")
      				uart_bufl[6] = 0xAA
      				print("Save lin.")
      			elif labels[i]=='ke':
      				sensor.snapshot().save("ke.jpg")
      				uart_bufl[6] = 0xBB
      				print("Save ke.")
      			elif labels[i]=='da':
      				 sensor.snapshot().save("da.jpg")
      				 uart_bufl[6] = 0xCC
      				 print("Save da.")
      			sensor.snapshot().save("other.jpg")
      			print("Save other.")
      Saveimg=Saveimage()
      uart = UART(3,115200)
      uart.init(115200,8, parity=None, stop=1)
      def ReceiveB():
      	global uart_r
      	size = uart.any()
      	if size<=len(uart_r):
      		for i in range(0,size):
      			uart_r[i] = uart.readchar()
      	if uart_r[0]!=0xAA:
      		LED(1).on()
      		LED(2).off()
      	elif uart_r[1]!=0xAF:
      		LED(1).on()
      		LED(2).off()
      	elif uart_r[2]!=0x05:
      		LED(1).on()
      		LED(2).off()
      		LED(1).off()
      		LED(2).on()
      uart_bufl = bytearray([0xAA,0xFF, 0xAA, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00])
      def uartsend(timer):
      	uart.write(uart_bufl)
      def updatesend(custom, cx, cy, distance):
      	i=0
      	sum = 0
      	add = 0
      	uart_bufl[2] = custom;
      	uart_bufl[4] = cx;
      	uart_bufl[5] = cy;
      	uart_bufl[6] = distance;
      	uart_bufl[3] = len(uart_bufl)-6;
      	while i<(len(uart_bufl)-2):
      		sum = sum+uart_bufl[i]
      		add = add+sum
      		i+=1
      	uart_bufl[-2] = sum;
      	uart_bufl[-1] = add;
      tim = Timer(2, freq=20)
      tim.callback(uartsend)
      	ReceiveB()
      	print(str(uart_r))
      	if uart_r[5]==0xDD:
      		img0 = sensor.snapshot()
      		Saveimg.Recognize(img0)
      		LED(3).on()
      		LED(1).off()
      		LED(2).off()
      		print("Saving......")
      	elif uart_r[5]==0xEE:
      		if uart_r[4]!=0x06:
      			print("Now is locking mode\r\n")
      			img1 = sensor.snapshot()
      			lockimg = ''
      			for i, detection_list in enumerate(net.detect(img1, thresholds=[(math.ceil(min_confidence * 255), 255)])):
      				lockimg = labels[i]
      				uart_bufl[7] = 0xCC
      				print('reading:'+lockimg)
      			img2 = sensor.snapshot()
      			for k, detection_list in enumerate(net.detect(img2, thresholds=[(math.ceil(min_confidence * 255), 255)])):
      				if (k == 0): continue
      				if labels[k]==lockimg:
      					print(lockimg+labels[k]+'\r\n')
      					for d in detection_list:
      						[x, y, w, h] = d.rect()
      						distance = int((80-center_x)*100*0.0024/0.42)
      						uart_bufl[4] = center_x
      						uart_bufl[5] = center_y
      						LED(3).on()
      						LED(1).off()
      						LED(2).off()
      						print('%d',distance)
      					uart_bufl[6] = 0x3C
      					print("Don't get picture!")
      		print("Wait enter a recognization mode!")
    • 先用示波器看看波形,看看到底是否有数据。其他的说法都是瞎猜。
