  • 我在生成的ei_image_classification.py文件中修改roi边框内容,只有一个边框可以正常识别?
      net = None
      labels = None
      except Exception as e:
          print(e)
          roil = (3,35,62,92)
          for obj in net.classify(img,roi=roil,min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5):
          roir = (126,35,62,92)
          for obj in net.classify(img,roi=roir,min_scale=1.0, scale_mul=0.8, x_overlap=0.5, y_overlap=0.5):
              print("**********\nPredictions2 at [x=%d,y=%d,w=%d,h=%d]" % obj.rect())
              predictions_list2 = list(zip(labels, obj.output()))
              for p in range(len(predictions_list2)):
                  print("%s = %f" % (predictions_list2[p][0], predictions_list2[p][1]))
              print(clock.fps(), "fps")
      Predictions at [x=3,y=35,w=62,h=92]
      0 = 0.000000
      4 = 0.000000
      8 = 0.996094
      Predictions2 at [x=126,y=35,w=62,h=92]
      0 = 0.996094
      4 = 0.000000
      8 = 0.000000
      5.22268 fps
      左边识别8右边识别4 但是右边roi中没有识别到
    • 别沉啊。。。。。。。。
    • 我没办法复现问题, 没办法判断是模型的准确度问题, 还是代码的问题.
