  • 174行一直报错,怎么解决
    • import sensor, image, time, os, tf, math, uos, gc, ustruct,pyb#,thread
      from pyb import UART,LED
      from pyb import LED
      rho_pid = PID(p=0.4, i=0)
      theta_pid = PID(p=0.001, i=0)
      THRESHOLD = (0, 36, -46, 50, 44, -83)
      threshold = (245, 255)
      sensor.set_vflip(False)
      sensor.set_hmirror(False)
      sensor.set_windowing((240,240))
      sensor.skip_frames(time=2000)
      sensor.set_auto_gain(False) # 颜色跟踪必须关闭自动增益
      sensor.set_auto_whitebal(False) # 颜色跟踪必须关闭白平衡
      roi = (10,0,30,30)#,(140,50,90,100)]
      led = pyb.LED(4)
      net = None
      labels = None
      min_confidence = 0.3
      flag = 0
      rho = 0
      theta = 0
      def track(rho,theta):
          if (line):
               if line.theta()>90:
                 theta_err = line.theta()-180
               if line.magnitude()>8:
                     # car.run(50+output, 50-output)
                  car.run(0,0)
              car.run(50,-50)
              pass
              #print(clock.fps())
              outuart(rho,theta)
      except Exception as e:
      colors = [
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
      uart = UART(3,115200)
      uart.init(9600, bits=8, parity=None, stop=1)
      def outuart(num):
          global uart
          data = ustruct.pack("<bbhhhhb",
                         0x2C,
                         0x12,
                         int(num),
                         int(88),
                         0x5B)
          uart.write(data)
          time.sleep_ms(1)
      data = [0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00]
      def UartReceiveDate():
          global Find_Task
          global Target_Num
          global x
          global data
          data[0] = uart.readchar()
          data[1] = uart.readchar()
          Target_Num=int(data[0]-48)*10+int(data[1]-48)
          #outuart(Target_Num)
      flag = 0
      rho = 0
      theta = 0
          if (line):
              if line.theta()>90:
      num = 0
      temp_num = 0
      UartReceiveDate
      #track(rho,theta)
      Target_Num = 0
      def find_number(temp_num):
          global tem
          global num
              if(num == 0):
                  sensor.set_windowing(1,1,100,100)
                  sensor.set_windowing(10,20,50,60)
              if(num == 1):
                  sensor.set_windowing(60,40,180,180)
                  sensor.set_windowing(90,40,50,60)
                  if (i == 0): continue
                  if (len(detection_list) == 0): continue
                  print(" %s " % labels[i])
                  tem = labels[i]
                  templatei ="/"+str(labels[i])+".pgm"
                  print(templatei)
                  outuart(tem)
                  num = num + 1
                  for d in detection_list:
                      [x, y, w, h] = d.rect()
                  sensor.set_windowing(240,240)
                  if(num == 1):
                      temp_num=int(tem)*10
                      print(temp_num)
                  elif(num == 2):
                      temp_num+=int(tem)
                      print(temp_num)
                      outuart(temp_num)
                      break
              if(num ==2):
                  break
          if(Target_Num==temp_num):
              print("okk")
              outuart(1)
              led = pyb.LED(2)
              print("error")
      UartReceiveDate()
          img = sensor.snapshot() # 拍一张照片并返回图像
          blobs = img.find_blobs([threshold=(245, 255),roi=(10,0,30,30)])
          if blobs==1:
          #如果找到了目标颜色
              for b in blobs:
                  #迭代找到的目标颜色区域
                  track(rho,theta)
              outuart("stop")
          #track(rho,theta)
          #find_number(temp_num)
    • emmm原因贴上来
    • 你代码写错了
      改为
      blobs = img.find_blobs(threshold=[(245, 255)],roi=(10,0,30,30))
