  • 运行很卡顿,有试过加if uart.any(): uart.readchar()但是没有改善还是掉帧很严重
    • import sensor, image, time, os, tf, math, uos, gc, ustruct, pyb
      from pyb import UART,LED
      sensor.set_windowing((240,240))
      sensor.skip_frames(time=2000)
      led = pyb.LED(4) # Red LED = 1, Green LED = 2, Blue LED = 3, IR LEDs = 4.
      template4 = image.Image("/4.pgm")
      templates = ["/1.pgm","/2.pgm","/3.pgm","/4.pgm"]
      rois = [(20,20,100,150),(140,50,90,100)]
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
      colors = [
      	(255,   0,   0),
      	(  0, 255,   0),
      	(255, 255,   0),
      	(  0,   0, 255),
      	(255,   0, 255),
      	(  0, 255, 255),
      	(255, 255, 255),
      uart = UART(3,115200)
      uart.init(9600, bits=8, parity=None, stop=1)
      def outuart(num):
      	global uart
      	data = ustruct.pack("<bbhhhhb",
      				   0x2C,
      				   0x12,
      				   int(num),
      				   int(88),
      				   0x5B)
      	uart.write(data)
      	time.sleep_ms(1)
      data = [0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00]
      def UartReceiveDate():
      	global Find_Task
      	global Target_Num
      	global x
      	global data
      	data[0] = uart.readchar()
      	data[1] = uart.readchar()
      	Target_Num=int(data[0]-48)*10+int(data[1]-48)
      	outuart(Target_Num)
      flag = 0
      num = 0
      temp_num = 0
      	UartReceiveDate()
      	if(num == 0):
      		sensor.set_windowing(1,1,100,100)
      		sensor.set_windowing(10,20,50,60)
      	if(num == 1):
      		sensor.set_windowing(60,40,180,180)
      		sensor.set_windowing(90,40,50,60)
      		if (i == 0): continue
      		if (len(detection_list) == 0): continue
      		print(" %s " % labels[i])
      		tem = labels[i]
      		templatei ="/"+str(labels[i])+".pgm"
      		print(templatei)
      		outuart(tem)
      		num = num + 1
      		for d in detection_list:
      			[x, y, w, h] = d.rect()
      			sensor.set_windowing(240,240)
      			if(num == 1):
      				temp_num=int(tem)*10
      				print(temp_num)
      			elif(num == 2):
      				temp_num+=int(tem)
      				print(temp_num)
      				outuart(temp_num)
      	if(num==2):
      		break
      		led.on()
              time.sleep_ms(150)
              led.off()
              time.sleep_ms(100)
              led.on()
              time.sleep_ms(150)
              led.off()
              time.sleep_ms(600)
      '''	else:
      		print(temp_num)
      		temp_num = 0
      if (Target_Num == temp_num):		 #发送回去
      	print("ok")
      	outuart("ok")
      	#print(clock.fps(), "fps", end="\n\n")'''
    • 第170行到116行,你加了sleep,当然帧率就慢了。
