  • FOMO学习之后一直提示错误是为什么?跟着视频的步骤一步步来的
      net = None
      labels = None
      min_confidence = 0.5
      except Exception as e:
          (255,   0,   0),
          (  0, 255,   0),
          (255, 255,   0),
          (  0,   0, 255),
          (255,   0, 255),
          (  0, 255, 255),
          (255, 255, 255),
          # of our objects
              for d in detection_list:
                  [x, y, w, h] = d.rect()
    • 升级到最新的固件。
