  • 图像太亮怎么办
    • 获取的图像太亮,导致有颜色的物体也显示成了白色
      前几天亮度还是正常的
      连窗户都能照
      但是现在连桌子都照不清楚了
      求解答!
    • 请先提供出现问题的代码。
      你需要先用hello world测试和教程里的程序测试。
    • # Find Rects Example
      # This example shows off how to find rectangles in the image using the quad threshold
      # detection code from our April Tags code. The quad threshold detection algorithm
      # detects rectangles in an extremely robust way and is much better than Hough
      # Transform based methods. For example, it can still detect rectangles even when lens
      # distortion causes those rectangles to look bent. Rounded rectangles are no problem!
      # (But, given this the code will also detect small radius circles too)...
      import sensor, image, time, lcd
      thresholds = [(21, 28, -14, -2, -11, 11),# generic_black_thresholds
                    (64, 73, 31, 52, 14, 39), # generic_red_thresholds
                    (98, 100, -6, 5, -5, 5),# generic_white_thresholds
                    (0, 30, 0, 64, -128, 0)] # generic_blue_thresholds
      sensor.set_pixformat(sensor.RGB565) # grayscale is faster (160x120 max on OpenMV-M7)
          # `threshold` below should be set to a high enough value to filter out noise
          # rectangles detected in the image which have low edge magnitudes. Rectangles
          # have larger edge magnitudes the larger and more contrasty they are...
          img.draw_cross(80, 60)
          for c in img.find_circles(threshold = 3900, x_margin = 10, y_margin = 10, r_margin = 10):
              circle_roi = [c.x()-c.r(),c.y()-c.r(),c.x()+c.r(),c.y()+c.r()]
              #for blob in img.find_blobs([thresholds[1]], roi=circle_roi, pixels_threshold=200, area_threshold=200, merge=True):
              img.draw_cross(c.x(), c.y())
              img.draw_string(90,80,'circle',color=(0,0,0))
              img.draw_string(90,90,'r=' + str(c.r()),color=(0,0,0))
              img.draw_string(90,100,'x=' + str(c.x()-80),color=(0,0,0))
              img.draw_string(90,110,'y=' + str(-c.y()+60),color=(0,0,0))
          for r in img.find_rects(threshold = 15000):
              if (r.w()-r.h())<10 and (r.w()-r.h())>-10 :
                  img.draw_string(20,80,'square',color=(0,0,0))
                  img.draw_string(20,90,'a=' + str((r.h()+r.w())/2),color=(0,0,0))
                  img.draw_string(20,100,'x=' + str(-r.x()+60),color=(0,0,0))
                  img.draw_string(20,110,'y=' + str(-r.y()+40),color=(0,0,0))
              print(r)
          for blob in img.find_blobs([thresholds[3]], pixels_threshold=200, area_threshold=200, merge=True):
              img.draw_circle(blob.cx(), blob.cy(), int((blob.h()+blob.w())/4), color = (0, 255, 0))
              img.draw_string(20,10,'led',color=(0,0,0))
              img.draw_string(20,20,'x=' + str(+blob.cx()-80),color=(0,0,0))
              img.draw_string(20,30,'y=' + str(-blob.cy()+60),color=(0,0,0))
          lcd.display(img)
          print("FPS %f" % clock.fps())
    • 和环境有关系
      我们仔细看一下这个代码。
      首先sensor.reset(),这个时候sensor是什么都不知道的,颜色肯定是不对的。事实上应该是很红。
      然后设置RGB565和QQVGA。
      然后skip_frames,也就是等待了2s的时间,这段时间内是用来让设置生效,其实也是自动设置sensor的颜色。
      最后,关闭自动gain和whitebal。
      所以,感光元件是有2s的时间来自动调节亮度和颜色的。
      经过我的测试,如果我把OpenMV用手盖住,然后运行程序,那么由于2s的自动调节颜色,就会很亮。
      如果我照灯给OpenMV,然后运行程序,那么就会暗一些。
