  • 运行时显示 OSError:[Erron 2]ENOENT
      from pyb import Pin
      from pyb import LED
      net = "trained.tflite"
      s=0  # ����������ֵ
      b=0  # ��������
              s=s+predictions_list[1][1]
              b=b+1
              if b>4:
                 b=0
                 if s/5 > 0.99:
                    led = LED(2) # ��led
                    led.toggle()
                    led.on()  #��
                    s=0
                    led = LED(2)
                    led.toggle()
                    led.off()  #��
                    s=0
                    #p_out = Pin('P7', Pin.OUT_PP)  # ����p_out��������
                    #p_out.high()  # ����p_out������
          print(clock.fps(), "fps")
    • https://singtown.com/learn/50872/
      按照视频步骤操作。
