  • mlx90640调色问题 调色不一致
    • import image, time, fir
      drawing_hint = image.BICUBIC # or image.BILINEAR or 0 (nearest neighbor)
      # Initialize the thermal sensor
      fir.init()
      w = fir.width()
      h = fir.height()
      if (fir.type() == fir.FIR_MLX90621):
          w = w * 10
          h = h * 10
      elif (fir.type() == fir.FIR_MLX90640):
          w = w * 10
          h = h * 10
      elif (fir.type() == fir.FIR_MLX90641):
          w = w * 10
          h = h * 10
      elif (fir.type() == fir.FIR_AMG8833):
          w = w * 20
          h = h * 20
      # FPS clock
              img = fir.snapshot(x_size=w, y_size=h,
                                 color_palette=fir.PALETTE_IRONBOW, hint=drawing_hint,
                                 copy_to_fb=True)
          except OSError:
              continue
          # Print FPS.
      为什么例程里这张图mlx90640调色是这样的0_1646455622400_c1a39c1e-848a-41dd-90df-afd570bdad7c-image.png
      而我仿照编写的程序 为了放在摄像头图像上
      import image, time, fir, sensor
      drawing_hint = image.BILINEAR # or image.BILINEAR or 0 (nearest neighbor) or image.BICUBIC
      #初始化摄像头,reset()是sensor模块里面的函数
      #设置图像像素大小
      fir.init(type=fir.FIR_MLX90640, refresh=32)
      w = fir.width()*10
      h = fir.height()*10
      ir_buffer =  fir.snapshot(x_size=w, y_size=h, pixformat=sensor.GRAYSCALE)
          ta, ir, to_min, to_max = fir.read_ir()
          to_max=to_max/0.92
          fir.draw_ir(ir_buffer, ir, alpha=256, hint=drawing_hint)
          img.draw_image(ir_buffer, 0, 0, alpha=256,color_palette=fir.PALETTE_IRONBOW)
      出来的图像调色是这样的
      怎么才能变成上面那幅图的调色
    • 我怎么感觉图像颜色反了,温度越低反而越深,怎么调整一下比较合适
