  • 为什么我的openmv用起来很卡顿,延迟特别高???
    • # Blob Detection Example
      import car
      green_threshold   = (76, 96, -110, -30, 8, 66)
      size_threshold = 2000
              print("x error: ", x_error)
              for b in blobs:
              print("h_output",h_output)
              car.run(18,-18)
    • 在最后加入fps,看看具体帧率,应该不会很低。应该是你颜色阈值不对导致总是找不到小球。
      import car
              for b in blobs:
              car.run(18,-18)
