  • 如何在同时识别颜色和圆形时,获得坐标,求大佬帮帮忙,新手
      sensor.skip_frames(time = 3000)
      def draw_hori_line(img, x0, x1, y, color):
          for x in range(x0, x1):
              img.set_pixel(x, y, color)
      # 绘制竖直线
      def draw_vec_line(img, x, y0, y1, color):
          for y in range(y0, y1):
          for c in img.find_circles(threshold = 8500, x_margin = 30, y_margin = 30, r_margin = 5,
                  r_min = 10, r_max = 11, r_step = 2):
              #area为识别到的圆的区域,即圆的外接矩形框
              print(statistics)
              #(0,100,0,120,0,120)是红色的阈值,所以当区域内的众数(也就是最多的颜色),范围在这个阈值内,就说明是红色的圆。
              if 19<statistics.l_mode()<53 and -7<statistics.a_mode()<78 and -4<statistics.b_mode()<64:#if the circle is red
                  img.draw_circle(c.x(), c.y(), c.r(), color = (255, 0, 0))#识别到的红色圆形用红色的圆框出来
              elif 0<statistics.l_mode()<30 and -9<statistics.a_mode()<20 and -34<statistics.b_mode()<17:#if the circle is red
                  img.draw_circle(c.x(), c.y(), c.r(), color = (0, 0, 255))#识别到的红色圆形用红色的圆框出来
          print("FPS %f" % clock.fps())
    • 你的c.x(), c.()不就是圆的坐标?
