  • MemoryError: Out of fast Frame Buffer Stack Memory!
    • Edge Impulse - OpenMV Image Classification Example
      #sensor.set_windowing((240, 240)) # Set 240x240 window.
      net = "trained.tflite"
      print(clock.fps(), "fps")
    • edge impulse只能在OpenMV4Plus上运行。OpenMV4不行。
