  • Nameerror: local variable referenced before assignment?
      想再限定一下矩形框宽度高度,为什么这样报错呢
      import os, nncu
      import pyb
      from machine import UART
      uart = UART(1, baudrate=115200)     # 初始化串口 波特率设置为115200 TX是B12 RX是B13
      sensor.set_brightness(2000) # 设置图像亮度 越大越亮
      sensor.skip_frames(time = 200)
      sensor.set_auto_gain(False)
      flag_tag = 0
      flag_OK = 0
      flag_num = 0
      flag_ani = 0
      flag_shoot  = 0
      animal_fruit = 0
      center_x = 0
      center_y = 0
      num = 0
      cnt = 0
      get = b'\x03'
      net_path = "model1.nncu"                          # 定义模型的路径
      labels = [line.rstrip() for line in open("/sd/labels_number.txt")]  # 加载标签
      net = nncu.load(net_path, load_to_fb=True)                          # 加载模型
      net_path2 = "78animal_fruit.nncu"    # _qm_model_18_0.7524_4033                             # 定义模型的路径
      labels2 = [line.rstrip() for line in open("/sd/labels_animal_fruits.txt")]   # 加载标签
      net2 = nncu.load(net_path2, load_to_fb=True)
      def family_name(tag):
          if(tag.family() == image.TAG16H5):
              return "TAG16H5"
          if(tag.family() == image.TAG25H7):
              return "TAG25H7"
          if(tag.family() == image.TAG25H9):
              return "TAG25H9"
          if(tag.family() == image.TAG36H10):
              return "TAG36H10"
          if(tag.family() == image.TAG36H11):
              return "TAG36H11"
          if(tag.family() == image.ARTOOLKIT):
              return "ARTOOLKIT"
      def find_max_ani(rects):
          max_size = 0
          min_w = 20
          max_w = 40
          min_h = 20
          max_h = 40
          abs_x = 5
          for rect in rects:
              if( rect.h() > 5 ): #and rect.w() > min_w and  rect.w() < max_w and rect.h() > min_h and rect.h() < max_h and abs(rect.w()-rect.h()) < abs_x ):
                  max_rect = rect
                  max_size = rect.magnitude()
          return max_rect
      def find_max_num(rects):
          max_size = 0
          min_w = 0
          max_w = 0
          min_h = 0
          max_h = 0
          abs_x = 0
          for rect in rects:
              if (rect.magnitude() > max_size and rect.w() > min_w  and  rect.w() < max_w and rect.h() > min_h and rect.h() < max_h and abs(rect.w()-rect.h()) < abs_x ):
                  max_rect = rect
          return max_rect
          #get = uart.read(1)
          img.draw_rectangle(((15,20,126,70)), color = (0, 0, 255))
          if(get==b'\x01'):
              rects = img.find_rects(roi=(10,30,140,80),threshold = 20000) #roi=(30,50,100,)
              for tag in img.find_apriltags(families=image.TAG25H9): # 指定apriltag类型为TAG25H9
                img.draw_rectangle(tag.rect(), color = (255, 0, 0))# 找到apriltag后绘制矩形框,将apriltag框起来
                img.draw_cross(tag.cx(), tag.cy(), color = (0, 255, 0))# 在apriltag中间绘制十字
                print_args = (family_name(tag), tag.id(), (180 * tag.rotation()) / math.pi)
                # 打印apriltag的类型、ID、旋转角度
                print("Tag Family %s, Tag ID %d, rotation %f (degrees)" % print_args)
                flag_tag = 1
          elif(get==b'\x02'):
              rects = img.find_rects(roi=(35,30,100,60),threshold = 2000)  #roi=(20,30,130,80)  threshold = 5000
              if(rects):
                  max_rect = find_max_num(rects)
                  if( max_rect.w() >10 and max_rect.w() < 50  and  max_rect.h() < 73 and ((max_rect.w()-max_rect.h() < 6 and max_rect.w()-max_rect.h() > 0) or (max_rect.w()-max_rect.h() > -6 and max_rect.w()-max_rect.h() < 0))     ):
                      img.draw_rectangle(max_rect.rect(), color = (255, 0, 0))   # 绘制矩形外框,便于在IDE上查看识别到的矩形位置
                      img1 = img.copy(max_rect.rect())                           # 拷贝矩形框内的图像
                      for obj in nncu.classify(net , img1, min_scale=1.0, scale_mul=0.5, x_overlap=0.0, y_overlap=0.0):
                        #print("**********\nTop 1 Detections at [x=%d,y=%d,w=%d,h=%d]" % obj.rect())
                        sorted_list = sorted(zip(labels, obj.output()), key = lambda x: x[1], reverse = True)
                        # 打印准确率最高的结果
                        for i in range(1):
                            #print("%s = %f" % (sorted_list[i][0], sorted_list[i][1]))
                            flag_num = 1
                            num = sorted_list[i][0]
          elif(get == b'\x03'):
              rects = img.find_rects(roi=(15,20,126,70),threshold = 2000)
              if(rects):
                  max_rect = find_max_ani(rects)
                  img2 = img.copy(max_rect.rect())                           # 拷贝矩形框内的图像
                  for obj in nncu.classify(net2 , img2, min_scale=1.0, scale_mul=0.5, x_overlap=0.0, y_overlap=0.0):
                      sorted_list = sorted(zip(labels2, obj.output()), key = lambda x: x[1], reverse = True)
                      # 打印准确率最高的结果
                      for i in range(1):
                          flag_ani = 1
                          animal_fruit = sorted_list[i][0]
          elif(get == b'\x04'):
               flag_shoot = 0
               flag_OK = 0
          elif(get == b'\x05'):
              rects = img.find_rects(roi=(15,30,126,70),threshold = 2000)
              if(rects):
                  max_rect = find_max(rects)
                  if(max_rect.w() >25 and ((max_rect.w()-max_rect.h() < 5 and max_rect.w()-max_rect.h() > 0) or (max_rect.w()-max_rect.h() > -5 and max_rect.w()-max_rect.h() < 0)) and max_rect.h() > 20 and max_rect.h() < 40):
                      flag_ani = 1
                      animal_fruit = 'apple'
          if(flag_tag == 1 and (tag.id() ==0 or tag.id() ==2 or tag.id() ==4 or tag.id() ==6 or tag.id() ==8)):
                uart.write("M")
                uart.writechar(2)
          elif(flag_tag == 1 and (tag.id() == 1 or tag.id() == 3 or tag.id() == 5 or tag.id() == 7 or tag.id() == 9)):
                uart.write("M")
                uart.writechar(1)
          elif(flag_num == 1 and (num == '1' or num == '3' or num == '5' or num == '7' or num == '9')):
                center_x = max_rect.x() + max_rect.w()/2
                center_y = max_rect.y() + max_rect.h()/2
                uart.write("M")
                uart.writechar(3)
                uart.write("W")
                uart.writechar((int)(center_x))
                uart.write("H")
                print(num)
          elif(flag_num == 1 and (num == '2' or num == '4' or num == '6' or num == '8' or num == '0')):
                uart.write("M")
                uart.writechar(4)
                print(num)
          elif(flag_ani == 1 and (animal_fruit == 'cat' or animal_fruit == 'dog' or animal_fruit == 'horse' or animal_fruit == 'pig' or animal_fruit == 'castle')):
                uart.write("M")
                uart.writechar(5)
                print("是个动物")
          elif(flag_ani == 1 and flag_OK == 0 and (animal_fruit == 'apple' or animal_fruit == 'banana' or animal_fruit == 'orange' or animal_fruit == 'durian' or animal_fruit == 'grape')):
                uart.write("M")
                uart.writechar(6)
                print("是个水果")
                flag_shoot = 1
          else :
                if(flag_OK == 0):
                    print("没找到了")
                    uart.write("M")
                    uart.writechar(0)
          if(flag_shoot == 1):
              uart.write("X")
              #uart.write("Y")
              #uart.writechar((int)(center_y))
              #print("正在打靶子")
              #print(center_x)
              #print(center_y)
              if((center_x - 80 < 5 and center_x -80>0) or  (center_x - 80 > -5 and center_x - 80 <0)):
                  flag_OK = 1
                  #print("打靶完成")
                  #uart.write("M")
                  #uart.writechar(7)
          flag_tag = 0
          flag_num = 0
          flag_ani = 0
          num = 0
          #print( "横坐标")
          #print(center_x)
          #print("纵坐标")
          #print(clock.fps())
    • 我没法运行啊,你这个nncu是啥。
    • 其实就是在定义找最大的矩形框函数里面加一个对框宽度和其他条件的限定,一加就报错
    • 你把nncu的代码发上来,或者提供一个不需要nncu的代码。
      没有代码我没办法调试。
    • @kidswong999
      import os, nncu
      import pyb
      m = 0
      flag_tag = 0
      flag_OK = 0
      flag_num = 0
      flag_ani = 0
      flag_shoot  = 0
      animal_fruit = 0
      center_x = 0
      center_y = 0
      num = 0
      cnt = 0
      get = b'\x05'
      flag_5 = 0
      def find_max(rects):
          max_size = 0
          min_w = 20
          max_w = 40
          min_h = 20
          max_h = 40
          abs_x = 5
          for rect in rects:
              if( rect.h() > 5 and rect.w() > min_w): # and  rect.w() < max_w and rect.h() > min_h and rect.h() < max_h and abs(rect.w()-rect.h()) < abs_x ):
                  max_rect = rect
          return max_rect
              return "TAG16H5"
              return "TAG25H7"
              return "TAG25H9"
              return "TAG36H10"
              return "TAG36H11"
              return "ARTOOLKIT"
          #get = uart.read(1)
          if(get==b'\x01'):
                #img.draw_rectangle(tag.rect(), color = (255, 0, 0))# 找到apriltag后绘制矩形框,将apriltag框起来
                #img.draw_cross(tag.cx(), tag.cy(), color = (0, 255, 0))# 在apriltag中间绘制十字
                #print_args = (family_name(tag), tag.id(), (180 * tag.rotation()) / math.pi)
                #print("Tag Family %s, Tag ID %d, rotation %f (degrees)" % print_args)
                flag_tag = 1
               flag_shoot = 0
               flag_OK = 0
              if(rects):
                      flag_ani = 1
                uart.write("M")
                uart.writechar(2)
                uart.write("M")
                uart.writechar(1)
                uart.write("M")
                uart.writechar(3)
                #print(num)
                uart.write("M")
                uart.writechar(4)
                #print(num)
                uart.write("M")
                uart.writechar(5)
                #print("是个动物")
          elif(flag_ani == 1  and (animal_fruit == 'apple' or animal_fruit == 'banana' or animal_fruit == 'orange' or animal_fruit == 'durian' or animal_fruit == 'grape')):
                if(flag_5 == 0):
                    uart.write("M")
                    uart.writechar(6)
               # print("是个水果")
                flag_shoot = 1
          else :
                if(flag_OK == 0):
                    #print("没找到了")
                    uart.write("M")
                    uart.writechar(0)
              uart.write("X")
              #uart.write("Y")
              #print("正在打靶子")
              #print(center_x)
              #print(center_y)
                  flag_OK = 1
                  #print("打靶完成")
                  #uart.write("M")
                  #uart.writechar(7)
          m = 0
          flag_tag = 0
          flag_num = 0
          flag_ani = 0
          flag_5 = 0
          num = 0
          #print( "横坐标")
          #print(center_x)
          #print("纵坐标")
          #print(clock.fps())
    • 第45行不对。当rects不为空列表,但是没有满足42行的条件时,会导致max_rect没有定义,所以就错了。
      解决办法:41行,添加max_rect = None。
      但是又会引起81行的错误,所以81行要加一句: if max_rect
      总结,你的代码逻辑是有问题的。
