  • 串口 十进制整数的无效语法 和列表索引超出范围
    • 0_1625709056236_956412f5-3ab5-4d64-bfa8-a6bc2009626b-image.png 0_1625709147157_4cb642a8-da00-443f-a8ae-0036dbe0e2d1-image.png
    • # Blob Detection Example
      import car
      green_threshold   = (99, 100, 127, 127, 127, 127)
      size_threshold = 2000
      a=0
      datx=0
      daty=0
          #for blob in img.find_blobs(green_threshold,invert=True,merge=True):
          blobs = img.find_blobs([green_threshold],invert=False,merge=True)
          if uart.any():
              dat = uart.readline().decode().strip().split(',')
              datx=int(dat[0])#机械臂x
              daty=int(dat[1])#机械臂y
              print(datx)
              print(daty)
              for b in blobs:
              if h_error<-500:
                  if h_error<-1500:
                      a=1
                  if h_error>-1700:
                      h_output=(abs(h_error))/100-3
                  #print("h_output",h_output)
                      if x_error>0:
                          car.run((h_output-2)*10-x_error*2,h_output*10)
                      elif x_error<0:
                          car.run(h_output*10,(h_output-2)*10+x_error*2)
                          car.run(h_output*10,h_output*10)
                 # print("h_utput",-h_output-x_output)
                      if x_error>0:
                          car.run(100-x_error*2,100)
                      elif x_error<0:
                          car.run(100,100+x_error*2)
                          car.run(100,100)
                  car.run(0,0)
                  time.sleep(0.001)
                  if a==1:
                      car.run(-99,-99)
                      time.sleep(0.1)
                      a=0
                  if h_error>8000:
                      if x_error>0:
                          car.run(-40,-20)
                      elif x_error<0:
                          car.run(-20,-40)
                          car.run(-40,-40)
                  elif h_error<3000:
                      if x_error>0:
                          car.run(20,40)
                      elif x_error<0:
                          car.run(40,20)
                          car.run(40,40)
                      if x_error>5:
                          car.run(-30,30)
                      elif x_error<-5:
                          car.run(30,-30)
              car.run(50,-50)
    • 你print一下看看data[0]是啥,反正不是数字。
