  • openmv追踪模板
    • 0_16246741png
      # Blob Detection Example
      import car
      green_threshold   = (76, 96, -110, -30, 8, 66)
      size_threshold = 2000
      template = image.Image("/cup1.pgm")
          blobs = img.find_template(template, 0.70, step=4, search=SEARCH_EX)
              x_error = max_blob[0]+max_blob[2]/2-img.width()/2
              print("x error: ", x_error)
              for b in blobs:
              img.draw_cross(int(max_blob[0]+max_blob[2]/2), int(max_blob[1]+max_blob[3]/2)) # cx, cy
              print("h_output",h_output)
              car.run(18,-18)
    • find_template 返回的只是一个,不是多个,所以不需要find_max
      blob = img.find_template(template, 0.70, step=4, search=SEARCH_EX)
      if blob:
          x_error = blob[0]+blob[2]/2-img.width()/2
          h_error = blob[2]*blob[3]-size_threshold
