  • 正确连接测距扩展版后运行代码,少部分呢情况下会出现ETIMEDOUT错误?
    • from machine import I2C
      from vl53l1x import VL53L1X
      import sensor, image, time ,math
      uart = UART(1, 115200)
      i2c = I2C(2)
      distance = VL53L1X(i2c)
      x=0
      y=0
          for c in img.find_circles(threshold = 3500, x_margin = 10, y_margin = 10, r_margin = 10,
              #area为识别到的圆的区域,即圆的外接矩形框
              print(statistics)
              #(0,100,0,120,0,120)是红色的阈值,所以当区域内的众数(也就是最多的颜色),范围在这个阈值内,就说明是红色的圆。
              if 0<statistics.l_mode()<100 and 0<statistics.a_mode()<127 and 0<statistics.b_mode()<127:#if the circle is red
                  img.draw_circle(c.x(), c.y(), c.r(), color = (255, 0, 0))#识别到的红色圆形用红色的圆框出来
                  x = c.x()
                  y = c.y()
                  #uart.write("find\r\n")
          print("range: mm ", distance.read(),x,y)
          #distance_head = distance.read()//256
          #distance_tail = distance.read()%256
          #data = bytearray([0x2C,0x18,x,y,distance_head,distance_tail,0x5B])
          #uart.write(data)
    • 引脚插的不紧,松了。
