  • 怎么同时识别多个特征点的物体?
    • *已经录入多个物体的特征点了,但为啥识别的时候没法同时识别他们。
      *我要怎么改代码使其能同时识别多个物体?
      import sensor, time, image
      # 重置传感器
      # 传感器设置
      sensor.set_contrast(3)
      #画出特征点
          if kpts:
              print(kpts)
              img.draw_keypoints(kpts)
              time.sleep_ms(1000)
      kpts1 = image.load_descriptor("/desc.orb")
      kpts2 = image.load_descriptor("/desc0.orb")
          if  (kpts1 == None):
              draw_keypoints(img, kpts1)
              if (kpts2):
                  if (match.count()>10):
    • import sensor, time, image
      # 重置传感器
      # 传感器设置
      #画出特征点
          if kpts:
              print(kpts)
              time.sleep_ms(1000)
          kpts0 = img.find_keypoints(max_keypoints=150, threshold=10, normalized=True)
          if (kpts0):
              match = image.match_descriptor(kpts0, kpts1, threshold=85)
              print(kpts2, "matched 1:%d dt:%d"%(match.count(), match.theta()))
              match = image.match_descriptor(kpts0, kpts2, threshold=85)
              print(kpts2, "matched 2:%d dt:%d"%(match.count(), match.theta()))
