星瞳实验室APP,快速收到回复
  • 关于openmv H743 RAM大小的问题
    • 在edge impulse中训练好后,用来识别数字,但是提示错误,用的是灰度图GRAYSCALE和QVGA
      MemoryError: Out of fast Frame Buffer Stack Memory!Please reduce the resolution of the image you are running this algorithm on to bypass this isse!
      代码如下:
      Edge Impulse - OpenMV Image Classification Example
      net = "trained.tflite"
      for obj in tf.classify(net, img, min_scale=0.5, scale_mul=0.5, x_overlap=0.1, y_overlap=0.1):
      print(clock.fps(), "fps")
      openmv4 plus可以解决吗
    • 这个程序只能在OpenMV4 Plus上运行
