04-ulab ulab数学操作返回错误'module' object has no attribute 'array'
import sensor, image, time, ulab as np sensor.reset() # 复位并初始化传感器 sensor.set_pixformat(sensor.GRAYSCALE) # Set pixel format to RGB565 (or GRAYSCALE) #设置图像色彩格式,有RGB565色彩图和GRAYSCALE灰度图两种 sensor.set_framesize(sensor.QQVGA) # 将图像大小设置为 (320x240) clock = time.clock() # 创建一个时钟对象来跟踪FPS帧率。 while (True): img = sensor.snapshot() # 拍一张照片并返回图像 a = np.array(img, dtype=np.uint8) print("mean: %d std:%d"%(np.mean(a), np.std(a)))
返回的错误
File "", line 13, in
AttributeError: 'module' object has no attribute 'array'
固件版本为最新3.9.4
更改为:
import sensor, image, time from ulab import numpy as np sensor.reset() # Reset and initialize the sensor. sensor.set_pixformat(sensor.GRAYSCALE) # Set pixel format to RGB565 (or GRAYSCALE) sensor.set_framesize(sensor.QQVGA) # Set frame size to QVGA (320x240) clock = time.clock() # Create a clock object to track the FPS. while (True): img = sensor.snapshot() # Take a picture and return the image. a = np.array(img, dtype=np.uint8) print("mean: %d std:%d"%(np.mean(a), np.std(a)))
@kidswong999 好的 谢谢
