  • 04-ulab ulab数学操作返回错误'module' object has no attribute 'array'
    • import sensor, image, time, ulab as np
      sensor.reset()                      # 复位并初始化传感器
      sensor.set_pixformat(sensor.GRAYSCALE) # Set pixel format to RGB565 (or GRAYSCALE)
      sensor.set_framesize(sensor.QQVGA)   # 将图像大小设置为 (320x240)
      clock = time.clock()                 # 创建一个时钟对象来跟踪FPS帧率。
          img = sensor.snapshot()         # 拍一张照片并返回图像
          a = np.array(img, dtype=np.uint8)
          print("mean: %d std:%d"%(np.mean(a), np.std(a)))
      返回的错误
      File "", line 13, in
      AttributeError: 'module' object has no attribute 'array'
      固件版本为最新3.9.4
    • 更改为:
      from ulab import numpy as np
      sensor.reset()                          # Reset and initialize the sensor.
      sensor.set_framesize(sensor.QQVGA)      # Set frame size to QVGA (320x240)
      clock = time.clock()                    # Create a clock object to track the FPS.
    • @kidswong999 好的 谢谢
