  • 为什么有线图传显示屏显示的画面会这么卡?帧缓冲区的画面都很流畅
      import sensor, image, time, os, tf,tv
      sensor.set_framesize(sensor.SIF)      # Set frame size to QVGA (320x240)
      #sensor.set_windowing((240, 240))       # Set 240x240 window.
      #sensor.skip_frames(time=2000)          # Let the camera adjust.
      tv.init(triple_buffer=False) # Initialize the tv.
      tv.channel(8) # For wireless video transmitter shield
      net = "trained.tflite"
          tv.display(img)
          print(clock.fps(), "fps")
    • tv.init(triple_buffer=False)
      改成True
    • 还是卡顿,关闭有线图传后,ide画面才变流畅,
      开有线图传画面就闪烁 卡顿这怎么办
