openmvh7plus无法使用条码检测示例
# Barcode Example # # This example shows off how easy it is to detect bar codes using the # OpenMV Cam M7. Barcode detection does not work on the M4 Camera. import sensor, image, time, math sensor.reset() sensor.set_pixformat(sensor.GRAYSCALE) sensor.set_framesize(sensor.VGA) # High Res! sensor.set_windowing((640, 80)) # V Res of 80 == less work (40 for 2X the speed). sensor.skip_frames(time = 2000) sensor.set_auto_gain(False) # must turn this off to prevent image washout... sensor.set_auto_whitebal(False) # must turn this off to prevent image washout... clock = time.clock() # Barcode detection can run at the full 640x480 resolution of your OpenMV Cam's # OV7725 camera module. Barcode detection will also work in RGB565 mode but at # a lower resolution. That said, barcode detection requires a higher resolution # to work well so it should always be run at 640x480 in grayscale... def barcode_name(code): if(code.type() == image.EAN2): return "EAN2" if(code.type() == image.EAN5): return "EAN5" if(code.type() == image.EAN8): return "EAN8" if(code.type() == image.UPCE): return "UPCE" if(code.type() == image.ISBN10): return "ISBN10" if(code.type() == image.UPCA): return "UPCA" if(code.type() == image.EAN13): return "EAN13" if(code.type() == image.ISBN13): return "ISBN13" if(code.type() == image.I25): return "I25" if(code.type() == image.DATABAR): return "DATABAR" if(code.type() == image.DATABAR_EXP): return "DATABAR_EXP" if(code.type() == image.CODABAR): return "CODABAR" if(code.type() == image.CODE39): return "CODE39" if(code.type() == image.PDF417): return "PDF417" if(code.type() == image.CODE93): return "CODE93" if(code.type() == image.CODE128): return "CODE128" while(True): clock.tick() img = sensor.snapshot() codes = img.find_barcodes() for code in codes: img.draw_rectangle(code.rect()) print_args = (barcode_name(code), code.payload(), (180 * code.rotation()) / math.pi, code.quality(), clock.fps()) print("Barcode %s, Payload \"%s\", rotation %f (degrees), quality %d, FPS %f" % print_args) if not codes: print("FPS %f" % clock.fps())
你是用的是哪个版本的固件,我用3.9.4没问题。
是传感器的问题吗
sensor.set_auto_whitebal(False)把这两行注释掉。
@kidswong999 已解决 谢谢
