  • openmvh7plus无法使用条码检测示例
    • # Barcode Example
      # This example shows off how easy it is to detect bar codes using the
      # OpenMV Cam M7. Barcode detection does not work on the M4 Camera.
      sensor.set_framesize(sensor.VGA) # High Res!
      sensor.set_windowing((640, 80)) # V Res of 80 == less work (40 for 2X the speed).
      sensor.set_auto_gain(False)  # must turn this off to prevent image washout...
      sensor.set_auto_whitebal(False)  # must turn this off to prevent image washout...
      # Barcode detection can run at the full 640x480 resolution of your OpenMV Cam's
      # OV7725 camera module. Barcode detection will also work in RGB565 mode but at
      # a lower resolution. That said, barcode detection requires a higher resolution
      # to work well so it should always be run at 640x480 in grayscale...
      def barcode_name(code):
          if(code.type() == image.EAN2):
              return "EAN2"
          if(code.type() == image.EAN5):
              return "EAN5"
          if(code.type() == image.EAN8):
              return "EAN8"
          if(code.type() == image.UPCE):
              return "UPCE"
          if(code.type() == image.ISBN10):
              return "ISBN10"
          if(code.type() == image.UPCA):
              return "UPCA"
          if(code.type() == image.EAN13):
              return "EAN13"
          if(code.type() == image.ISBN13):
              return "ISBN13"
          if(code.type() == image.I25):
              return "I25"
          if(code.type() == image.DATABAR):
              return "DATABAR"
          if(code.type() == image.DATABAR_EXP):
              return "DATABAR_EXP"
          if(code.type() == image.CODABAR):
              return "CODABAR"
          if(code.type() == image.CODE39):
              return "CODE39"
          if(code.type() == image.PDF417):
              return "PDF417"
          if(code.type() == image.CODE93):
              return "CODE93"
          if(code.type() == image.CODE128):
              return "CODE128"
          codes = img.find_barcodes()
          for code in codes:
              img.draw_rectangle(code.rect())
              print_args = (barcode_name(code), code.payload(), (180 * code.rotation()) / math.pi, code.quality(), clock.fps())
              print("Barcode %s, Payload \"%s\", rotation %f (degrees), quality %d, FPS %f" % print_args)
          if not codes:
              print("FPS %f" % clock.fps())
    • 你是用的是哪个版本的固件,我用3.9.4没问题。
      是传感器的问题吗
    • sensor.set_auto_gain(False)
      把这两行注释掉。
    • @kidswong999 已解决 谢谢
