  • 更新固件以后官网的追小球代码报错了
    • 0_1617626606650_识别出错.png 就像这样,一识别到小球就报这个错误
    • 官网追小车实例的代码
      car.py
      from pyb import Pin, Timer
      ain1 = Pin('P0', Pin.OUT_PP)
      ain2 = Pin('P1', Pin.OUT_PP)
      bin1 = Pin('P2', Pin.OUT_PP)
      bin2 = Pin('P3', Pin.OUT_PP)
      ain1.low()
      ain2.low()
      bin1.low()
      bin2.low()
      pwma = Pin('P7')
      pwmb = Pin('P8')
      tim = Timer(4, freq=1000)
      ch1.pulse_width_percent(0)
      ch2.pulse_width_percent(0)
      if inverse_left==True:
      left_speed=(-left_speed)
      if inverse_right==True:
      right_speed=(-right_speed)
      if left_speed < 0:
          ain1.low()
          ain2.high()
          ain1.high()
          ain2.low()
      if right_speed < 0:
          bin1.low()
          bin2.high()
          bin1.high()
          bin2.low()
    • 更新了代码,刷新一下网页,不会报错了。
    • @kidswong999 好的,解决了谢谢
    • @kidswong999 把后面这一串代码加在之前的代码后面是吗
