  • 如何自动调整曝光时间 使得光源在不同的亮度条件下产生的效果都是一样的
    • 请在这里粘贴代码
      Template Matching Example - Normalized Cross Correlation (NCC)
      This example shows off how to use the NCC feature of your OpenMV Cam to match
      image patches to parts of an image... expect for extremely controlled enviorments
      NCC is not all to useful.
      WARNING: NCC supports needs to be reworked! As of right now this feature needs
      a lot of work to be made into somethin useful. This script will reamin to show
      that the functionality exists, but, in its current state is inadequate.
      import time, sensor, image
      Reset sensor
      Set sensor settings
      Max resolution for template matching with SEARCH_EX is QQVGA
      You can set windowing to reduce the search image.
      #加载模板图片
      sensor.set_auto_whitebal(True) # turn this off.
      sensor.set_auto_exposure(False,
      exposure_us = 37945)
      sensor.set_auto_gain(True, gain_db_ceiling = 7.0) # Default gain.
      print(clock.fps(),sensor.get_gain_db())0_1614504693395_M4}YT385~(NJAJ4WTH(WN{B.png 0_1614504711174_AIJIK8}WRVJ3JT~~5`W7)3G.png
    • @rdig如何自动调整曝光时间 使得光源在不同的亮度条件下产生的效果都是一样的 中说:
      这里
      光源不论多强都能实现下面那张图的效果
